Object mapping failed - Solved
brunocesarrrr
I'm experiencing a troublesome problem and I recently changed my computer to the same one that I updated the Daz version, so I do not know exactly where the problem is
When I double click some figures on Smart Content Pane, like Aiko 6 I get this message:
"Could not open file: /People/Genesis 2 Female/Characters/Aiko6.duf
File does not exist"
Some figures work, others don't. The problem is happening with some wardrobre items as well.
So these are the actions that I taked:
Settings on Install Manager:
Settings->Downloads
D:\Users\Public\Documents\DAZ 3D\InstallManager\Downloads
Settings->Installation-> 64 bit Software
Settings->Installation-> 32 bit Software
D:\Users\Public\Documents\DAZ 3D\x32
Settings->Installation->Content
D:\Users\Public\Documents\My DAZ 3D Library
On Daz Studio:
Edit->Preferences->Content->Content Directory Manager
Daz Connect Data
D:\Users\Public\Documents\DAZ3D\Studio/My Daz Connnect Library
Daz Studio Formats
D:\Users\Public\Documents\My Daz 3D Library
D:\Users\Public\Documents\DAZ3D\My Library
Poser Formats
Based on a YouTube video, I also did:
Right click on Content Pane->Content DB Maintenance->Re-import Metadata
In the same figure if I right click -> "Browse to file location" it opens the directory D:\Users\Public\Documents\My DAZ 3D Library\People\Genesis 2 Female\Characters
The Aiko6.duf file is present and is even selected
Already uninstalled and re-installed Daz Studio, Postgre CMS and Aiko 6 itself.
What am I forgetting? What else I can do?
Had youn installed using Connect (that is, from withint Daz Studio)? Have you run DIM or Daz Studio as admistrator (if not, continue not to)? What security software are you running?
I always install with DIM,
Never used as administrator, when needed, Windows ask me permission and I grant.
I user Kaspersky.
Right now, DIM show me that I have 2114 products installed, using Daz since june 2016, just facing this error now, random products.
Sometimes, after install using DIM, I go to Daz Studio, in content library, the product have a grey square, up right. Right click, and select to install, the square go green and when it's done become a blue square down right.
If you install by right-click in DS then you are using Connect. That appears to mean that DS is not seeing the isntallation that DIM performed for some reason. Can you find the DIM-installed content, without using the right-click in the content Library, under Daz Studio Formats>My DAZ 3D Library?
Yes I can, the .duf file is located in D:\Users\Public\Documents\My DAZ 3D Library\People\Genesis 2 Female\Characters, I can locate it going though Windows Explorer and when I click Browse to File Location inside Daz it goes to the same directory.
If I double click Aiko6.duf it opens normally, if I save a scene with Aiko6 model, close and open the program and reload again I have no errors.
It is something related to Smart Panel and Content Library
It does seem that there is a two stage issue:
I've not heard of other kaspersky users with similar problems, however.
Your last comment gave me an idea:
- I opened DIM and completely uninstalled Aiko 6.
- Then I opened Studio and for my surprise the product was still there.
- So I attempted to uninstall and reinstall within Studio.
- That was it, start to work again. But I wasn't satisfied yet because on DIM the product was listed was pending to install.
Finally I uninstalled again within Studio, close it, went to DIM and installed there. Now it is done!
The strange thing is that I always installed only with DIM, never faced this. The problem began when I changed the disk D: from one computer to another, reinstalling only Daz Studio.
I ended up not meshing with Kaspersky
Thank you very much
If you click Download Filters on the Ready to Download tab of DIM you can deselect Connect installed to avoid doubling up in that pane - it won't, however, hide zips that are already downloaded.
Richard,
I thank you again, but for me, uninstall on Daz and install on DIM was the best way out, every product stays in the same configuration.
The challenge now would be locate every problematic product, but as this would take a lott of time, I intend to fix just when I try to use a product and get an error.
