Weight Mapping tool...doesn't seem to do anything
I've seen video of people changing the weight mapping on objects so they do not deform using dforce.
I figured I would try it out.
When I go to use the tool it does not change the area I'm using the tool on...it stays red...nothing changes to blue...
Can't figure out what I'm doing wrong...
JD
  • MadaMada Posts: 2,065
    Press Alt while using the paintbrush and it will subtract instead of add :)
    Hmmm
    I'll try that again...but I'm pretty sure I already did that...
    JD
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,504
    yeah I found it nonfunctional too assumed user error so I chose the geometry selection brush from the horizontal list and painted bits with that instead then clicked fill selection with value slider at zero to create nailing points like I do in Virtual World Dynamics and it seemed to work esp on conforming bits.
