My Genesis 3 males are deformed
I've been using Genesis 3 male since it came out and this problem just started recently. I can't think of anything I've installed lately that would effect G3M. I uninstalled Daz Studio, and installed 4.10. I also re-installed G3M and the morph packages. This is happening with both of my computers, (they share the libraries) and all of my G3M characters. There is no problem with G2 or G8 or G3F. Anyone ideas on what is causing this, and how to fix it?
332 x 391 - 38K
  • barbultbarbult Posts: 27,491
    This kind of thing is almost always caused by installing some product or freebie. Take another close look at what you have installed recently. Try uninstalling recent products and especially freebies and things from other stores. See if the problem goes away. If so, reinstall one by one to figure out which one is the culprit.
  • I've a feeling a store prodct did this, where the bone adjustments weren't correctly hooked up to trigger only with the shape, but if so it was fixed - make sure you didn't install content from an an older set of files on a back-up.
  • I recently needed a very specific outfit that I could only find for M3, so I converted it to Genesis using Wardrobe Wizard. Is that the sort of thing that cause an issue like this? I can't think of anything i've installed that would morph or modify the G3M figure itself.
  • No, this is not at all likely to come from a clothing set.
  • Well, I replaced my library with a back-up copy and that solved the problem. It will take a while to figure out what exactly I lost in the process. Thanks for the help and information.
  • I seem to be having the same issue. If you discover the cause will you please update us here.
  • Did you have skinchangers installed?
