setting dForce simulation parameters - SOLVED
Is there a way to fix the dForce simulation parameter settings so they always appear as set by the user each time DS is opened?
If not, DAZ could you please implement this.
Post edited by IsaacNewton on
Set them up the way you want, save a scene, and use the file loading options in Edit>Preferences under the Starup tab (on DS launch) and Scene tab (File>New in DS) to load that scene. Can also be used to load default render options, cameras, lights etc.
Thanks Richard, that did it.
