How to show modified settings only?
Hi guys,
I modified several settings of a character and I have a few questions:
- is there a way to view only the modified Parameters? (if I select Parameters > Actor, I have to scroll down all the parameters and find them among all the default ones)
- is there a way to reset the pose settings of a body part in the Posing tab, without checking in the same way?
Thanks
  • Right above the part of the tab that displays the character there is a button labeled Currently used; click that and it will show only the specific items that have been applied.
  • yagakisanyagakisan Posts: 65
    edited October 2017
    Wow that was so simple... frown
    And is there a way to select all the items? I tried holding Shift but it doesn't works.
    EDIT: Ops, I tried with CTRL + A and it seems to work.
    Thanks!
    Post edited by yagakisan on
  • DaWaterRatDaWaterRat Posts: 2,885
    I don't use the posing tab, but in the Parameters tab, if you select the part you need reset, there's a "Zero selected" available through the options menu.
  • MIH_BADMIH_BAD Posts: 65
    Well, thank you. I think I scrolled as long as to the other side of the world :) this helps so much... I knew there need to be something!!! Thank you !
