weird problem on viewport
ISIKOLISIKOL Posts: 386
edited October 2017 in The Commons
Hello Guys...after installing ds 10 i have a weird problem with viewport....its all white! (as you can see on the screen) outside iray preview i can see the guides on ground but inside preview area is all an annoying white....
i unistalled the software and reinstalled it...nothing....
i have resseted everything and stills nothing....
when im creating a new screen is white again....
do you have any idea what is going on? i need to work and this is very disturbing....
Mod Edit:-  Image removed due to nudity.
Post edited by Chohole on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,852
    you have iray view enabled not textured view so its rendering interactive mode
  • NorthOf45NorthOf45 Posts: 5,929
    Likely a style change is needed. From the top menu select Window -> Style -> Customize Style. In the popup, go to 6. Viewports and change the colour to 64/64/64 (the default). I have some vendor scene files that change the viewport instead of changing the environment background colour. Very annoying.
  • ISIKOLISIKOL Posts: 386
    @northof45 you are a savior!!!!! Jesus...i dont know how did that changed!!!! thank you so much!!!!
