Easy question - expecting hard answer...lol
father1776
I will express what I want to do in the simplest terms.
I want to attach/glue a small object (like a small cube) to the >skin< of a model.
I want the cube to stay attached to that spot on the skin regardless of limb movement, act like a cube glued to the skin at that point.
Move relative to the skin it is on and not the skeleton.
The cube should maintain the same angle and position of the spot it is attached (it should not flip or spin in place when the spot it is glued to moves)
I would like the easiest way to do this using only daz, if it is possible.
thanks
Create a rigid follow node and parent your object to it,should work;)
Lots of tutorials out there, google is your friend they say!
thxs
perfect, exactly what I need
