Farmer's daughter outfit for genesis
RPGMaker247RPGMaker247 Posts: 146
edited April 2013 in The Commons
I'm looking for a farmer's daughter type outfit for genesis/v5/a5.
I found the cut-off jeans but cannot find the top. Is there such a "creature"?
The image below (clothes wise) is what I'm searching for.
356 x 480 - 51K
Post edited by RPGMaker247 on
  • KatteyKattey Posts: 2,899
    There is a free one
    http://www.sharecg.com/v/53533/browse/11/Poser/Tied-Top-for-V4
    Also for V4 but would work with Genesis
  • RPGMaker247RPGMaker247 Posts: 146
    Close but no cigar.
    I'm looking for Genesis/V5/A5 not V4/A4. Thanks for trying though.
    edited April 2013
    I don't know about the other two but free TiedTop converts to Genesis very nicely (I used Bodysuit->Loose autofit with V4 Adjusted Autofit helper from here http://www.sharecg.com/v/55187/browse/21/DAZ-Studio/Genesis-Autofit-correction-for-V4-clothing). It also keeps all of its own V4 morphs which can serve as adjustment morphs.
    The Genesis is a mix of V5 and some other female morph
    949 x 884 - 130K
    Post edited by Kattey on
  • Zev0Zev0 Posts: 7,123
    edited April 2013
    Imposer12 said:
    Close but no cigar.
    They work perfectly fine On Genesis as mentioned by FSMCDesigns
    Post edited by Zev0 on
    Imposer12 said:
    Close but no cigar.
    Your call, but seeing as most V4 items work fine with genesis, i doubt you will see many vendors making genesis only versions of clothing that already works.
    Here is a quick render with genesis and all items on her being for V4
    563 x 903 - 907K
  • wancowwancow Posts: 2,708
    Imposer12 said:
    Close but no cigar.
    Hongyu is trying to convert everything (She?) has made to Genesis. If you contact Hongyu, you'll probably get a positive response and a priority might be put on that piece.
  • Tramp GraphicsTramp Graphics Posts: 2,435
    I also use the V4 Tied top for a "country girl" character using Genesis. My character Tommie Jean. It works perfectly with morphs intact (I use Transfer Utility in DS 4.0 for the conversion).
    2000 x 1125 - 936K
  • RoguePilotRoguePilot Posts: 239
    You've missed out http://www.daz3d.com/adventure-girl-essentials-bow-v4
    Again for V4, but should work well with Genesis.
  • FirstBastionFirstBastion Posts: 8,076
    BadKitteh used to have a clothing set called Toolgirl, that had both a tied off top and shorts, but doesn't look to be available any longer.
    http://www.badkittehco.com/phpBB3/viewtopic.php?f=6&t=39
    Zev0 said:
    Imposer12 said:
    Close but no cigar.
    Hey Zev,
    I understand what you're saying but not everyone wants to convert items as there is always the risk that the shape you wish to use may cause distortions.
    Personally I don't like buying products that I will then have to convert. I'm still working my way through converting past purchases to genesis and am only too aware that not everything will fully work. What looks like a good conversion on a basic shape will often require more work on a more extreme shape. So my choice is to buy products designed for genesis. If I want something that isn't already available then I will either do without or make it myself.
    Just my opinion for what it's worth and no intention to offend. Just offering a personal perspective.
    Pendraia said:
    Hey Zev,
    I can understand a small bit of that, but unless your final shape is close to the genesis base for which the clothing was designed for there will still be a bit of distortion. As for converting, there is no converting, just fit to and 2 clicks and it's on. Just trying to wrap my head around this as i have had immense success using gen 3 and 4 clothing with genesis (with long skirts and footwear being the exception), it is one of the selling points for me and DS4.
    Pendraia said:
    Hey Zev,
    First if you buy from vendors like Sickle who does many custom morphs that is not always the case. Or who understand how to design a mesh that works with the genesis figure that is less likely to happen.
    Some meshes work better with converting than others.
    Buying gen 4 products to convert to genesis is a bit like buying a lottery ticket you don't know what you'll get or whether it will convert well.
    I have done many conversions myself and for the basic shape some things will convert fairly easy with smoothing , collision and the weight slider adjusted to suit. However once you start to apply more shapes and different poses that is not always the case and this all takes time.
    Also if all the bits of the mesh are not connected it will come apart when you smooth.
    As someone who works full time and has very little spare time I would just prefer to buy something that works out of the box.
    As I said earlier it is a personal opinion others may disagree...that's what makes life interesting. ; )
