Question about using Lune Nails product (22204)
Hey everyone,
I've recently purchased the Lune Nails for Genesis 3 Females product located at [https://www.daz3d.com/lune-nails-for-genesis-3-female-s ]
I've run inti a bit of an issue when trying to render the nails.  (I'm using IRAY.)
I've applied the shape, texture and shader but the render doesn't come out right at all.  In the main scene view the nails look perfect, but after rendering they come out completely white. You can see a slight texture on them but not really all that much!  See the images below which will explain better :)
This is the view in the main scene window - notice everything looks AOK:
https://i.imgur.com/Mgx1yx5.jpg
This is the view after rendering:
https://i.imgur.com/F1AVasC.jpg
I have followed all instructions, and changed the UV maps to the LuneNails one.  Everything appears fine until I attempt to render, then the nails always come out white.  I've use the American flag nails in this example, but I have tried multiple and the results always turn out the same.
Any ideas?  It's probably something I've missed but I really cant work it out!
  • Richard HaseltineRichard Haseltine Posts: 111,468
    edited October 2017
    Are you sure you used the Iray settings, not the 3Delight? The product includes both.
  • TATSU 3DTATSU 3D Posts: 224
    Yeah, I'm positive.  I always filter to show IRAY only.  Unless they're incorrectly labelled which I doubt?  I can try using the ones marked as 3DL and see what happens...
    I have this product and it works fine for me. Maybe try uninstalling and reinstalling? Sometimes that works for me when products go wonky. Even closing DS and reopening it can sometimes help.
