detailing figure
Hi all! Is any way to draw bump or normal map and see result in real time in prewiev window in dazstudio?
Not to my knowledge. The map is stored in the TEMP folder, and unless the naming changes in the surface settings, it won't be loaded again, hence no update to the render. Even if you use editing in LIE, you have to close that first to see the results.
Hmm... how authors makes "HD addons", for example https://www.daz3d.com/victoria-8-hd-add-on? They are draws details in L.I.E.?
No, for HD Add ons, DAZ provides their PAs with a special plugin that will allow them to import HD morphs they sculpted in ZBrush, for example. If you are not a PA, you can't make a morph that has HD, only "regular" morphs. That said, the HD morphs are work on the mesh directly, while the normal and bump maps (and don't forget about the displacement maps) work on the existing mesh slightly differently).
