how to add morph target ?
Atlantis
Hi...
I created in daz studio 4.5 a character preset from a poser character...
now i want to ad a face morph to it, but no matter what i try it always resizes the whole figure when using the morp dial ???!!!!!
What I am doing wrong ?
Are you sure the morph you are applying is a face-only morph? Some figures don't have such...
Sorry, that's the only point that comes to my mind atm. .
That sounds like using the wrong preset in the import dialogue. How did you create the OBJ for the morph, from the base OBJ supplied with the figure? If so then you'd want to use the Poser preset. If you used an OBJ exported from DS then you'd want to use the same preset importing the morph as you used exporting the OBJ.
I exporting the head as object ...
You need to export the whole figure, and as I said you need to make sure youi use the same prset on export adn on import.
Ok will try that again...
