Adrian Moustache wierdness
MariaTortillia
Whn I pose a gen8male figure wearing the Adrian moustache the ends of the moustace dont follow the pose as if they are pinned to thier original starting position and stretch in wierd ways back to the ending position of the figure,
I'm assuming you autofit the moustache to G8M as this hair is designed for G3M.
There is a way around it. Make sure your G8M is not selected, then load the moustache. With the moustache selected in the scene tab, click the drop down menu in the top corner of the scene tab and select edit - Scene Identification. Where it says preferred base clock the ... icon and scroll down to select Genesis 8 Male. Click accept.
Now right click on the moustache in the scene tab and fit to G8M. The distortion should hopefully be fixed.
You could also select the ends of the moustache with the Geometry Editor tool, then in the Node Weight Paintbrush tool fill the weight map for the head with (presumably) 100%.
thanks Ill try that and that
