How can you get clothing to automatically fit?
ToobisToobis Posts: 993
Pls not this is with Daz3 (not 4)
So when I fit clothing on V4 or M4 characters I often tweak their body size etc and then it causes a problem as their bodies go into and through the clothing because the clothing does not move out with the body.
Is there a good way to be able to move clothing with the changing body so it always stays fitted on? thx.
  • Richard HaseltineRichard Haseltine Posts: 111,816
    Right-click on the clothed figure and from the menu select Morph Follower.
  • BWSmanBWSman Posts: 0
    edited April 2013
    Edit: Beaten to the answer by Richrad H.;-)
    Post edited by BWSman on
  • ToobisToobis Posts: 993
    edited April 2013
    no this is not an option with my right click. (in pic) are you sure you know I am still using Daz3?
    1280 x 1024 - 243K
    Post edited by Toobis on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,714
    only in Daz studio 3 advanced not standard
    oh. What is DS advanced? I guessing you have to pay for it. Is there a link pls?
    no longer for sale but a magazine had it on a disc I believe
    dammit. I guess i'm screwed then.
    can you use 4?
    if you need to use 3 there is morphing clothes or crossdresser you can buy (I have both)
    or try exporting the fitted clothes from 4 as a morph target maybe? (oops you need morph loader for that too!)
  • JaderailJaderail Posts: 0
    I'm not 100% sure only DS3 Advanced had Morph Follower. The fastest way to see is this. Morph Follower is not used on the clothing item it is used on the figure. You Right Click on any of the M4, if Morph Follower is not listed then you do not have it. In that case you could use Deformers to adjust the clothing after you pose the figure. If you do not get Morph Follower let me know and I'll point you to some very good Tut's and threads on Deformers.
  • BejaymacBejaymac Posts: 2,010
    edited April 2013
    Morph Follower was one of the Advanced features you had to pay for, along with the likes of shader mixer and the UBER system.
    Chances are the clothing already has the morphs you need in them, if they were bought here then there is a pretty good chance they will "super conform" to your figure when it's been "fitted to" it. Sadly the same can't be said for content bought at the other stores, the morphs will more than likely be there, it's just they are done poorly meaning you have to find and dial them manually.
    super conform = morphs in clothing will automatically dial up when you dial up the same morph in the figure.
    Post edited by Bejaymac on
