Weird effect on my render (3Delight)
Mescalino
I have a fish eye like effect on my render and i dont know why. I choose this angle because here the effect was the least without l;oosing my picture.
When i tilt the angle it becomes far worse, its kinda like a fisheye effect but when i do a render from top view its not there but as soon as i tilt my view its there. Mostly with that wall as background.
I know the area is optimized for iRay and im using 3Delight but i hope that that is not whats causing it (even though it would not surprise me). And if so is there something i can do to make it 3Delight 'compatible' ?
1788 x 790 - 295K
that looks like it's the window pane that is reflecting what is in the room, for some reason. Have you checked the material? If in doubt, convert it to Iray using the Iray Ueber Shader, and make sure the the reflective properties are tuned down.
Alternatively, check the gloss settings in the 3Delight surface settings, and dial them down until the effect vanishes.
