Problem with Lotus Shoes
I'm having trouble fitting the Lotus Shoes https://www.daz3d.com/lotusgown-accessories to Genesis 2 Female. I have Victoria 4 for Genisis 2
But every time I try fitting the shoes to Genesis 2. Then end up fitting between the feet instead of going directly on them.
Is there any way I can get them to fit properly?
  • You are setting Victoria 4 as the original figure in the AutoFit dialogue?
  • LeanaLeana Posts: 13,608
    The problem is that those shoes are not made for the default pose, there's a "high heels" pose for V4 included with the set. So it can't fit the default pose on G2F, you will need to adjust the feet too.
    I believe so. That what I did with the other Lotus items and they fit just fine. In fact selecting victoria 4 is what causes them to fit between the feet.
    So if I load up victoria 4 and copy that pose onto genesis 2. It might fit proper?
    Probably not as the shoes will bend with the feet, maintaining their incorrect relationship. You would most likely need to edit the rigging to stop the foot bones from influencing the shoes (or you could just load two copies of the shoes, hide one foot of each, and parent one to each shin of the Genesis 2 Female figure, then pose the feet in the shoes).
    I found setting the fit to victoria 4 skirts make them fit onto the feet but the toes stick out. Is there any way to scale the individial toes of genesis 2 so they hide inside the heels?
  • Actually nevermind. I managed to tweak the shoes and get them to fit around genesis 2 females feet. Thanks for the help though.
