Supersuit Smoothing?
TimmothTimmoth Posts: 108
It has none? >:(
I'm finding Genesis morphs that the suit won't cover, especially in latest release packages. Normally smoothing would solve minor poke-through like I've been getting, but smoothing is nowhere to be found in the Parameters tab, neither can I find anywhere else that I can choose to apply smoothing to the suit.
Why is it not available?
  • MedzinMedzin Posts: 337
    Many objects don't not have smoothing modifier applied by default.
    Select the article in the scene tab, then use the active scene option flyout, choose "Edit-->Apply Smoothing Modifer"
  • TimmothTimmoth Posts: 108
    edited June 2012
    Aha, thankyou, that works.
    Although it's taking a half hour and only 55% processed... (I've got 16Gb Ram too...)
    Post edited by Timmoth on
  • SkirikiSkiriki Posts: 4,976
    How much smoothing and collision you put in? o_O
    Smoothing 20
    Collision 3
    It's up to 85% now, about another half hour later.
    That's odd, although you could yank smoothing down to 10 or so and collision up to 4. You are running 64-bit version of the program, right? How many cores you got?
    Although I think you might want to use the included morphs to push all surfaces (both seams and plates) up a notch before using smoothing.
  • Richard HaseltineRichard Haseltine Posts: 111,516
    20 is quite high, and for some morphs will make poke-through worse - smoothing, as it says, smooths out the bumps. Try lowering Smoothing and if need be slightly increase collision iterations, which is the part of the process that should address poke-through.
    Yep, 64 bit, and 4 cores.
    Something's definitley weird though. The viewport is empty now, even when I reset the camera view, rotate the cube, etc.
    It won't even render, so I'll have to restart the program....
