succubus addons issue with G8
i'm trying to use the succubus tail from this on G8, but when it fits to the model, it had no texture and cannot be posed, it just sticks straight out. i need this fixed for an art commission ASAP. help appreciated.
  • LeanaLeana Posts: 13,529
    Since they're not made for G8 I suppose you autofitted the tail ?
    The tail certainly had custom bones for posing, and those were lost when you used autofit. You best bet would be to not autofit it but position it manually and parent it.
  • The Succubus tail is not made for Genesis 8 so it is AutoFitting, which is removing the custom bones. It's also no longer set up to GeoGraft and so isn't hiding the figure's legs. There are ways to keep the custom bones, and you can hide bones or use the Geometry Editor to hide polygons (even set up a new AutoHide group) but I suspect you still won't get an exact match, and it certainly won't be good enough to weld.
    I think the lack of textures may simply be the way the tail loads - have you tried applying one of its presets? If thsoe fail as they are Hierarchical presets, apply them to the tail fitted to Geensis 2 Female, theh select the tail and save a regular materials preset which should work.
  • HellcatHellcat Posts: 98
    still not working
  • After doing what?
    eh, i said screw it and didnt bother parenting it to anything. no one is gonna see the back anyway
