Daz3D Figure Shapes doesn´t show up in Shaping Tab
Hello,
I am new to Daz Studio so i watched some Tutorials. While watching the Shaping Tutorial i wondered why it doesn´t look like my Shaping Tab.
Anyhow I figured out the problem. I installed Daz3D on my (D:) Drive but it will only load stuff on the (C:) Drive in the Documents folder. I can´t affort
so much space on (C:). What can I do now?
You need to add the directories you want to use to Daz Studio (and Install manager if you use that). If you are using Install Manager click the gear icon in the top-right corner to open prefrences, then go to the Installation tab there and click the + button to add the folder(s) you want to use (the folder that holds the Runtime and Data folders is the oen you want). Then download http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start and drag it into an open DS viewport to run it - that will get the folders from DIM, to make sure they match. If you use Connect and want to change the directory used you will need to use the Content Directory Manager (launched from Edit>Preferences>Content) to set it to use your preferred location, then move the contents of the old folder to the new.
