How to remove category display on preview ?
Hello everybody !
I would like to know you to create a preview of a prop/wearable or everything else without display the category.
For example these preview with Material(s) in yellow or Wearables(s) in green. How to remove this text ?
Thank youuuuuu so much ! :))
The text is added by the content management system - if you hover your mouse over the item the pop-up will not have the flash; if the item includes or you create an itemname.tip.png image (256 pixels square) the pop-up will use that, not the base thumbnail.
Thank you Richard, That'a a very good info for personalise pop-up !! :)
But if I notify that if I create/save a prop and then I rename it, the text disappears like I want. I would like to know if there is a direct way to do that ?
The text disappears if you rename (or move) the file outside DS because in doing so you break the link with the CMS database, I'm not sure if you could do that by design inside DS.
It disappears when I rename inside DS (right click on preview/Rename).
Thank you for reply, it's not worth looking for more :/
