Where'd My Products Go? [Solved ...Mostly]
3Diva3Diva Posts: 12,058
edited October 2017 in The Commons
I just downloaded the new beta and it says my products "don't exist". My product files look like this:
And when I double click on them it says: "Could not open file : file does not exist".
How do I get my products to show up?
Edit - Never mind. I figured it out (I think). I went to Content Library >> Content Directory Manager and then had to manually point Daz at where I have the content saved.
I still have some files missing, so I might have some saved where I don't know about. Oy... lol
Post edited by 3Diva on
  • Pack58Pack58 Posts: 750
    edited October 2017
    Do you use the 3 staderd standard D/S librarys (My Library, My DAZ Library and Connect) or did you set up some of your own?
    Post edited by Pack58 on
  • 3Diva3Diva Posts: 12,058
    edited October 2017
    Pack58 said:
    Do you use the 3 staderd D/S librarys or did you set up some of your own?
    Yeah, I have like three locations because I filled up my tiny C drive, then I have another slightly less tiny drive that I also filled up. So I have Daz content across three different drives. lol
    I managed to figure out how to tell Daz where to find some of it. But I'm still missing some files.
    OK, sorry that's all I can think off at present.
    It's ok. I found most of the files, so I'm not going to sweat it too much at the moment. :) Thankfully it looks like installing the beta didn't whipe out the previous version of Daz that I had. So at least all my flies are intact in one version. :)
  • Cris PalominoCris Palomino Posts: 12,963
    The Public Build and the General Release do not share settings. Run the script @ http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/save_mapped_paths/start in the General Release to generate a script that you can then run in the Public Build to make both have the same paths mapped.
  • xyer0xyer0 Posts: 6,505
    edited October 2017
    I was having this same problem with DIM for the past 10-14 days. I solved it tonight by opening the Ready to Download tab on DIM and removing the check/tick on the Install After Download box at the bottom. Then I downloaded my files (Start Queue). Next, I went to the Ready to Install tab and selected all the files I wanted to install and clicked Start Queue. After that, my files showed up properly in the Products tab.
    Post edited by xyer0 on
    Oh nice! Thank you, Cris! :)
    I'll try this if the script that Cris linked doesn't solve the issue. Thanks, xyer0. :)
