why is mirror reflection jagged?
srieschsriesch Posts: 4,243
edited April 2013 in Daz Studio Discussion
I'm working with a mirror, and the reflection in the mirror is jagged, like it isn't being antialiased or something. What causes this and/or how do I fix this?
(reflection on the left, actual object on the right)
489 x 308 - 68K
Post edited by sriesch on
  • KhoryKhory Posts: 3,854
    I could be wrong but for some reason I'm wanting to say that it means your shading rate is to low. I could be miss remembering though.
    Could it be that your mirror surface isn't perfectly flat?
  • ErdehelErdehel Posts: 387
    I could have written the same question a few days ago. Higher quality render settings didn't help. Then I changed the mirror textures and the jagging was gone...
    You could try using another mirror texture or build one yourself with the help of tutorials here in the DAZ forums.
  • JaderailJaderail Posts: 0
    Shading Rate and X Y samples do play into this. Don't rule them out till you test a better Render setting.
  • Richard HaseltineRichard Haseltine Posts: 111,992
    Reflections are certainly more sensitive to shading rate than directly seen items - remember that lower is better, but slower, for shading rate.
  • srieschsriesch Posts: 4,243
    edited April 2013
    Looks like Render > Render Settings > Shading Rate was it. In a quick test I randomly selected 0.1 instead of 1, and that made a difference. I'll play around with the render setting to find the most appropriate value.
    (I also first tried creating a new primitive plane and making it reflective, that didn't change it, so in this case the original mirror surface settings weren't the problem.)
    Thanks everybody!
    123 x 171 - 22K
  • zededd2000zededd2000 Posts: 111
    Just want to jump in and say thanks too. This is the exact same problem I was having and the exact same fix worked :)
