dforce is the best Force
So I made one pic to test stuff, and of course picked the most obnoxious pose as possible for simulation. Pretty good!
1414 x 2000 - 2M
«1
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,818
    yes
  • SkirikiSkiriki Posts: 4,976
    Hey peeps, where are settings for uh um like thick sort of rubber hose?
    ...for no specific reason, why?
    ...no I don't have Singers of Chzor on screen, gawd.
    " thick sort of rubber hose"
    #Hollering
  • Aave NainenAave Nainen Posts: 1,108
    All of the surface settings can be adjusted and the settings required for any given effect will greatly depend on mesh density etc.
    #Hollering
    *whistles innocently*
    No, look, just...
    Yeah, but has some enterprising soul premade ones, because it is almost midnight and I don't want to get experimental, or I won't sleep tonight. laugh
  • kyoto kidkyoto kid Posts: 42,481
    ...she needs to be sticking her tongue out
    Yeah just saw the demo and I am quite impressed. Indeed, a "Knock the Socks off" feature as I mentioned on the main thread.
    I maded more. And more obnoxious poses to test! And now that I found where I can add the dforce surface, I'm getting closer to experimental mood, except midnight and need to be in the bed!
    1414 x 2000 - 2M
    1414 x 2000 - 2M
    1414 x 2000 - 2M
  • LyonessLyoness Posts: 1,641
    put some hair on that poor girl!!
    edited October 2017
    Nuuuuuuu, it's her style!
    (Or I am just lazy, your pick.)
    FYI everyone should feel free to post their tests of stuff to this thread.
    Post edited by Skiriki on
  • Tweaked version of Tween Julie 7, wearing the Bardot Outfit.
    1000 x 1300 - 892K
  • Pack58Pack58 Posts: 750
    Going to take me a while to work it all out but yay.
    1200 x 849 - 649K
  • 3Diva3Diva Posts: 12,058
    I'm lost - what's dforce?
    edited October 2017
    Post edited by Pack58 on
  • exstarsisexstarsis Posts: 2,128
    Well, rather, it's the new Daz physics engine, which is starting with clothes (but they promise will simulate more things eventually).
    Ohhh That sounds exciting!! Is it only certain clothing that can be dynamic or is it any clothes?
  • Well, rather, it's the new Daz physics engine, which is starting with clothes (but they promise will simulate more things eventually).
    Most anything from what I can tell, though some folks are having trouble getting it to work right now.
  • QuasarQuasar Posts: 711
    It's new today so it's no wonder you haven't heard of it yet ;) It's a physics engin for DS and will definitely be something I use a lot once I get it all figured out. So far it works as a nice dynamic cloth simulator but I'm looking forward to new physics capabilities in the future too.
  • BeeMKayBeeMKay Posts: 7,019
    edited October 2017
    For details, check here: https://www.daz3d.com/forums/discussion/203081/dforce-start-here#latest
    It creates amazing results when it works as it should... I have a problem with 9 out of 10 clothes I tried to convert for use in dForce. If it works, it's great, but right now, the frustration factor is killing the fun for me.
    Oh, and you can create amazing simplosions with it, too.
    Post edited by BeeMKay on
  • DaWaterRatDaWaterRat Posts: 2,887
    It also apparently only works in DS 4.10, so until that's out of Beta, I'll have to enjoy it vicariously, and then take advantage of all the experience once I can play. :)
  • ghastlycomicghastlycomic Posts: 2,531
    Broot-woot-doot-doot. Disagree. Broot-woot.
    I managed to drape a plane over a sphere! So yeah, in theory it can work with anything modeled correctly.  I foresee a bright future of rigged clothes with preconfigured draping surfaces. Maybe a new opportunity for collaboration if people end up good at it. Ooooh. Imagine buying texture add-ons that come with surfaces that have been preset to behave like silk or brocade or velvet...,
  • FistyFisty Posts: 3,416
    They would need to be set up for a specific item though, shader presets for use on anything arn't going to work because how something behaves is very dependant on how dense the polygon count is, and how the lines travel between the polys.  If you have a pair of pants with a lower polycount you can make the simulation settings really loose and flowy but it's still going to look fairly ridged.
    edited October 2017
    You can see the difference with just your sphere and plane, quadruple the polycount on your plane and it will drape much differently at the same simulation settings.
    Post edited by Fisty on
  • Broot-woot-doot-doot. Disagree. Broot-woot.
    Yay for G-Force!!
    Though I'm also excited for dForce
    Yeah, I was definitely thinking as part of a materials set, not a shader set. I’m just... in love with lush textures but not a huge fan of endlessly tweaking settings to make stuff drape properly so I will definitely be in the market for the preconfigured stuff. Though I guess most of that will be for G8 and I’ve been slow getting into that....
    TBH, a lot of clothes are at "base" level (I know that rather well, since I have had to add some SubD to handle some crankiest things) -- what happens if you add SubD to it and then run the simulation? Worth a shot.
    I don't know if it uses base or sub-d to calculate in that instance. =)
    It has a setting for base or screen resolution base of the simulation, at least.
  • LlynaraLlynara Posts: 4,772
    edited October 2017
    So far, I managed to make a dress explode. More reading to do!
    989 x 881 - 945K
    Post edited by Llynara on
    hahah I kind of like it. :)  Maybe with some artsy filters to make it look like a painting -name it "Passion". :)
