Mirror image flip for poses?
Hi, Is there a way to flip a characters pose horizintally, which would change the pose to be the mirror image of its current appearance?
  • Assuming you are using Daz studio, use the Edit>Figure>Symmetry command (shift y by default).  For Nodes you want Root, for propagation you want recursive, for Direction Swap left and Right, and choose the mirror trunk nodes option. If you used pose controls, on the figure, rather than the transforms on individual bones when setting the initial pose then you need to use the Edit>Figure>Bake to Transforms command (shift B) first.
  • MarcCCTxMarcCCTx Posts: 947
    edited October 2017
    You could use the DA Mirror Pose Script that came with https://www.daz3d.com/da-cache-22-pose-set-for-scott-6. It seemes to work with almost anyone.
    Post edited by MarcCCTx on
