problem with v4 poses...
hello there...i bought this pose pack for v4 https://www.daz3d.com/yeehaw
and i installed them through install manager....
i cant find them anywhere in my content library when im loading ds....
do you have any idea what is going wrong?
thanks in advance!
  • ArtiniArtini Posts: 11,043
    Since it is a Poser package, it will go most likely to Poser runtimes.
    The easiest way to find out, is to open the zip file and look at it contents.
    On Windows computer, DIM downloads its data to C:\Users\Public\Documents\DAZ 3D\InstallManager\Downloads
  • 3Diva3Diva Posts: 12,058
    The fastest way to find older content like that (IMO) is to look under the Products library in Daz.
    For that product you'll likely find it under: Products >> Y >> Yeehaw
    if you installed via DIM the install manager, go to the "Installed" tab, locate the product and right click. You'll see "Show Installed Files". click that, and a box will come up showing exactly where they got installed.You can also click on them as they are links and they will open up the folder.
    If you installed via Smart Content within DS, either change your menu up the top to "installed first" to show the most recent ones, or type "Product Name" in the search bar (including the quotes). Given that they are an older RDNA item that came over here, they will have no metadata at all and will be under "Lost and Found".
