Difference between OOT hair and Universal Hair Shader
Griffin AvidGriffin Avid Posts: 3,883
edited October 2017 in The Commons
I have OOT hair that's supposed to do wonders.
https://www.daz3d.com/outoftouch
Just saw this
https://www.daz3d.com/universal-hair-shader-for-iray
Which looks like the same product but works for every hair there is.
I thought I could use OOT's shaders with every hair set too.
Me thinks I got it wrong and THIS UNIVERSAL hair shader is the one that should be in every library.
Any opinions, comparisons or experience or just keep observations and opinion, conjecture and hair-based lectures?
Post Script: I use a lot of older hair pieces (Like M/V 4 era and wonder if this new shader is a better 'look' than the converted to iray ones that ussing iray creates......
Worthy purchase, yeah, nay?
Ahhhh update: this is the product I thought OOT was.
I own this already
https://www.daz3d.com/hair-lustre-shaders-for-iray
Looks like redundancy is afoot.
Post edited by Griffin Avid on
    My favorite hair shader is actually sold at Rendo. If is OOT IrayPair Hair Shaders for DAZ Studio Iray
  • Griffin AvidGriffin Avid Posts: 3,883
    What about the lustre product? That seems to be it, too......
  • FistyFisty Posts: 3,416
    This is my favorite too, I use it on almost every hair that wasn't made by OOT, even ones that already have good Iray materials.
  • I have the lustre hair shaders and I reallllly like them.
  • LlynaraLlynara Posts: 4,772
    edited October 2017
    I don't have Univeral Hair Shader, but I've used most of the others and they all are great for different reasons:
    • OOT Iray Hair Repair (Rendo) is gorgeous on everything. I use it all the time.
    • PhilW's Hair Lustre product works great on older hairs, right on top of the old texture. It's a great alternative to OOT when retexturing the hair doesn't turn out the way you thought it would. A lot of old textures have baked in shadows and highlights. Phil's goes over top of that and often looks great. It's also very good for shining light through (Marshian's new Rim Light Rig for Iray also has great shaders for backlighting.)
    • OOT hairs are amazing and come with hair blending options that I'm just starting to really use. It's amazing what you can do with them. With your sci fi renders, I could see you using these a lot. (I'll work up a post on my Patreon for you soon!)
    • IDG's hair shaders are good too. They seem to have a "drier" look that's great for men. Sometimes OOT's are too shiny and pretty for a guy. Not always. If you want a different texture, these are good.
    • Some people love Slosh's UHT shaders. I haven't used them a lot, only because I use the others so much. They seem to work just fine, I just prefer OOT and PhilW.
    • There are also some Iray great shaders that came over with RDNA. I have them but haven't had a chance to really try them out.
    Post edited by Llynara on
  • Oso3DOso3D Posts: 15,115
    Personally, I end up starting with UHT and then applying PhilW's. ;)
    UHT generates more fine textures, PhilW applies settings I like better.
  • Personally, I end up starting with UHT and then applying PhilW's. ;)
    My same process. I have OOT Pair, UHT, & Lustre and use them all depending on the particular need. But it seems like 8/10 times I go for UHT with Phil's shader on top. Maybe I'm spoiled but I just like having the options and see what I come up with.
  • 3Diva3Diva Posts: 12,058
    Excellent reviews on some of the top hair shaders. Thank you for taking the time to put this together. It can be confusing trying to decide which one to get. I've been meaning to get a hair shader for ages but am always frozen with (what if I get X and Y is better? or if I get X and Z is better?) Lots to choose from and it's hard to know what they're going to look like under your favorite light and render settings. Thank you for the rundown of your favorites. That's helpful! :)
    I'm putting in a vote for Slosh's UHT shaders I use this a LOT its very versatile and you can do a LOT of different blending with this.  I do have the others as well except for the Iray hair repair and I will have to look and see if I have the OOT hairs. I don't thinks so.  But the others are also very good and I find that I mix and match a lot but I start my base hair with Slosh's uht and hair salon products.  Then use the others to add more to it if I need to.  You can layer a ton of different colors into hair with the Hair salon.
    Excellent review and listing. C'mon somebody. I know there's a few power users around.
    Write a Daz Survival guide, already and let it get stickied and updated all the time.
    The starter makes the first entry and is the host. All the other posts get added in over time.
    It should be
    1) Essential Purchases (like why you need Morphs, etc)
    2) Lighting (Ghost lights and portrait lights etc..)
    3) Backdrops, backgrounds, Domes and such
    4) Scene Optimizer
    5) "best' skin shaders
    6) hair shaders
    7) Generation Gaps explained (what genesis works with what, V4 and M4 and ...and ...)
    8) Fit to and Parenting....
    Maybe some VERY common troubleshooting stuff (Black renders/camera in object/no lights)
    Lost the menu system....
    Rendering tips....PNG transparency.....
    Cameras...DOF and Perspective/depth
    A general top ten list of 'first purchases' would be great- even if the notes say 'add to wishlist now and purchase when on sale'...etc..
    Shopping strategies, like for Base Characters and Bundles and Stacking and ...and PC+....
    Folks, to my knowledge, there isn't an Iray Hair Repair product. I believe somewhere along the way there was a typo for OOT's IrayPair Hair Shader.
    The product works similarly to Slosh's UHT2 shader. In my experience, both are very similar in outcome and are generally improvements on the typical hair shaders (though some PA's shaders are better than others). In the end, the choice between these two may often come down to which one has the exact shade you want.
    All of the products mentioned in this thread are good enough that "bad hair" in your render is you, not the products. laugh
    +1 - you made me laugh
  • exstarsisexstarsis Posts: 2,128
    edited October 2017
    I want to put a word in for Sveva's Kandy hair shaders. I was surprised because I don't associate Sveva with hair at all.... but she does spiffing shaders and after a friend and I did a bunch of comparisons with the various 'universal' hair shaders out there, Kandy edged ahead by a nose. _Only_ a nose, so probably not worth picking up if you're already happy with something... although she does good ombre presets. But if you're in the market, hop over and check 'em out.
    Post edited by exstarsis on
  • mmkdazmmkdaz Posts: 335
    I can tell you OOT hair shader was a great improvment in my renders.
    I knew I was forgetting one! I bought those and have been meaning to try them out, but I rarely get past OOT. LOL!
    @avxp You're always welcome. I'm going to do a series of tutorials on my Patreon site, maybe a different theme every month. I don't know everything, still learning every day, but I am good at documenting things and I love to experiment and write about it, so there's that. I'll make it "a work in progress" lol, just like me!
    @divamakeup So glad you found it helpful! I remember when the first ones came out and they were a gamechanger. They still are.
  • DMaxDMax Posts: 637
    @SereneNight Seems like OOT has a store here as well... is there a comparable product sold in OOT's store here?
  • shadowhawk1shadowhawk1 Posts: 2,211
    I agree with you on this, This shader pack is well worth the money and works for any hair on the market.
  • brvsnbrvsn Posts: 213
    It should be
    4) Scene Optimizer
    6) hair shaders
    I really wish some daz guru will do somehting like this..
    I would also add two separate category for stuff sold by different PA but with similar features:
    1. pose helpers (a huge category from simple helpers to extreme pose optimizations)
    2. skin materials customization. this category has a large number of products as well
    It would also be nice to have a thread in the forum but I guess that would maybe look as non correct to most PAs.. :(
  • nicsttnicstt Posts: 11,715
    .... agreed for transmapped.
  • TaozTaoz Posts: 10,345
    @outrider42 says in this thread  https://www.daz3d.com/forums/discussion/390206/dear-hairmakers/p1   that OOTs IrayPair shaders no longer are fully compatible with the Iray version in DS which has changed over time.  May be true for other hair shaders as well.
