Navigating in speed of light
mahhen
Ok. i have been reading forums and at the moment there doesn't seem to be one perfect solution for navicating in large scenes. For now the best way seems to be making cameras and using them as reference points. This thread address pretty mush same issue. https://direct.daz3d.com/forums/discussion/152741/moving-objects-great-distances
Yet the easiest way would be useing fast object, i could be just standard primitive with added options. In parameters setting there could be increase movement speed dial and in the scene tab it could have options like transfer object to location or camera or light,,, It would be fast and easy. If there is already something like this inform me please, i'm still a noob :)
If you want to place one object on another, use the 'align' tool (open window: Pane: Align) - you can align: stack (put it on top) or other position.
To move an object large distances quickly, I'd just put a big number in the parameters tab under 'Translate' (x, y or z). Otherwise the computer has to calculate and redraw for every step and that will be slow with complex objects.
