Rons Atmospheric Bundle
Where do I instal files for Rons Atmospheric Bundle? Aren't these photoshop brushes? They come in an .exe file.
  • fixmypcmikefixmypcmike Posts: 19,738
    Yes, they're photoshop brushes -- install to wherever you normally install brushes for your application (PS, GIMP, etc.)
  • Joe.CotterJoe.Cotter Posts: 3,362
    edited April 2013
    Yes they are Photoshop brushes, so they go in the 'brushes' folder in Photoshop. When you run the exe, it will save them to a folder. I suggest you save them to a temp folder then move them manually but if you're feeling adventurous you could install them right to your brushes folder (which shouldn't be a problem.)
    Hehe, crosspost. Another benefit to saving to temp folder is that you can then zip them and save them so you don't have to rerun the exe if you need to reinstall them in the future.
    Post edited by Joe.Cotter on
    Personally I would install to a temp folder, as they are large brushes, and if installed directly inot PS can clog up the program when you open it. I always clear my brushes after each session and re install them from the load brush screen when I need to use them.
  • SzarkSzark Posts: 10,634
    Yep I am with chohole on this. All my additional PS brushes are on my USB HDD. I just load what brushes I need when I need them.
