Problem with Genesis Clothing Conversion Loading in Poser Pro (Updated)
This was originally a slightly different question, but I changed it because what I was converting it turned out had a Genesis version that for whatever reason didn't get loaded.
I followed the directions in creating Poser companion files in the Daz3D docs. I'm trying to get a stocking onto Genesis in Poser Pro 2012. I loaded it on Genesis in DS 4.5 (64 bit), and told it what is was/who it was for, then saved it out as a duf file (save as Support Asset>Figure/Prop Asset). I tried saving it both where the Poser .obj file was and also in a DS folder in the library (when I didn't it wouldn't show up in the library for me to convert) Then I did the right click on the content library tab and chose Create Poser Companion Files. I changed the base path to my runtime folder and left the "use metadata" on. I left the supplemental path alone. I tried adding the copy option too.
When I tried to load it in Poser both times via the library I get "Poser.error: Couldn't create unimesh geometry" I don't know if I did something wrong. And yes I have DSON installed in Poser, the SR for Poser, and the Genesis starter essentials, etc.
Jamie
