Iray render setting problem
Orpheus13
Hello,
Having some issues I restored the Iray Render settings to default.
Now my renders are as fast as they are bad, with a very low resolution.
How and to which settings should I change that ? Thanks.
In terms of quality check the "Progressive Render" settings.
I usually set the "Render Quality" to "Off", so it renders until the "max. Samples" or time value is reached.
If you set this to "On", Daz Studio decides based on the "Render Quality" and "Converged ratio" when it's time to stop the render. This can cause grainy images.
"General" is to set resolution etc., "Tone Mapping" for the photography things like Shutter Speed and ISO and "Environment" for IBL lighting, Dome orientation etc..
These are the most important ones to start with.
Here is a good overview of what some of these settings do:
Kind regards, Eagle99
Thanks a lot, that was really helpful !
And now I've got a whole lot more videos to watch...
Yes, there are a lot of things to learn about Iray Render settings ...
