EcVh0 skin anomaly
The line right near the chin, the face looks like she is wearing make-up that does not match the tone of her skin. The lighting and angle are not the cause as its in all my shots.
920 x 1180 - 600K
  • AndySAndyS Posts: 1,449
    I see what you demonstrated.
    I once had the same experience with a merchant ressource. I returned it. Seems as if those textures are worse compared to the ones of the standard actors.
    But also translucency and transmission setting can have some influences.
  • EcVh0EcVh0 Posts: 535
    Hey Vanishot!
    i just had a look at your render, seems like you are using pale skin shader? Does it have the same problem with the normal shader?
    it seems to be a problem with texture itself, the line isn't actually at the change of textures (so it's not the texture difference problem) I will have a try to see if I can remove the darker shade at the bottom part of the texture and will let you know how it goes :)
    EcVh0
    Thank you.
  • OminousAutumnOminousAutumn Posts: 405
    edited September 2017
    EcVh0 said:
    Hey Vanishot!
    EcVh0
    This is a render of V8 fresh out the box. If this is what you were meaning, than I am not noticing the same issue.
    Also Im afraid I lost track of our personal message thread in case you sent something, I have not seen it/no messages in my inbox.
    1568 x 1742 - 1M
    Post edited by OminousAutumn on
  • whatcha think?
    558 x 536 - 201K
