DAZ fails to load after crash and I cant get replacement install files
To set the scene:-
Was using DAZ with the iRay preview and my system froze. After reboot it wouldn't open DAZ pulling up a "Not Windows 10 or corupt file" error.  So I needed a reinstall.
I can't get to a set of instal files.
Fortunately, I was previously running a Public Build version and my Install Manager had a non public build version available so I have loaded that. Now I have no versions of DAZ available in my install manager and I can't get to an installation set if it crashes.
Just go to the "Free Software" download? It doesn't work; try it. If you are logged in and click the software download button it just takes you to your purchased products page. Not much use at all.
So, in summary, I have a working version of DAZ installed which I am now afraid to use as, when I get a system crash, I will be up a creek with no paddle.
  • SimonJMSimonJM Posts: 6,100
    What about the product library?
  • You are a top person of the highest order.
    It was taking me to my product library but I couldn't find DAZ, only my purchased assets.  I obviously wasn't looking hard enough.
    Still, I now have an install exe in my download file so should be good to go again.
    The whole "Not Windows software.." bit happend with IM a few days back - I installed a product from my order page rather than from IM and it killed IM. I had an IM installer exe in my dowloads file though so it was a quick fix.
    Thanks again.
  • If you uninstall through Install Manager you should then be able to reinstall - however, this does sound a bit like the issue some users were having with McAffee a few weeks back, is that your security software?
  • Hi Richard, you are straight in there with McAffee - hatefull as it is.
    I am hoping that, now I have an install.exe file in my download folder (I deleted the previous on to save space) a quick reistall should solve the issue as and when the crashes come about. I have no doubt they will continue hence my concern about not having a quick rebuild previously (seemingly) without access to an install file.
    Good luck!
    edited September 2017
    Nobody has to use Mcafee or Avast on their own personal computer. There are plenty of sufficent anti-virus and anti-malware paackages that don't act like virus' in their own right.
    Post edited by fastbike1 on
    I am fast comming to that conclusion. What do you recommed as an alternative as I don't want to run without anything.
    Today I went to load DAZ after having shut it down succesfully previously (ie not after a crash) and it was corrupted again.
    Apparently it isn’t just a crash the corrupts DAZ.
    I did the suggested scan and this didn’t throw up any errors or change anything.
    I had to perform a reinstall from the “install” file which I now have in my downloads.
    It transpired (after the reinstall) I had DAZ and DAZ Public Beta – these create two completely different directories in Program Files.  The Public Beta DAZ exe route was corrupted.
    This is all something of a pain obviously.
    And another thing which really upsets my OCD. I can't uninstal Public Beta, as Windows doesn't recognise it as a legitimate aplication now, but I still have the icon left in my Sart listing. After failing to uninstall I had deleted the Public Beta directory but still the annoying icon persists in sitting there.
  • John SimsJohn Sims Posts: 360
    John Sims said:
    ., but I still have the icon left in my Sart listing. After failing to uninstall I had deleted the Public Beta directory but still the annoying icon persists in sitting there.
    Well at least I have solved that issue.
    Post edited by John Sims on
    And the agro continues. It did the whole "Bad Image" error tonight so I tried to do an install from my saved install.exe file and the install crashed.  I then had to uninstall DAZ via setup before it would do the reinstal for me.
    This is becomming something of  pain in the back side.
