V4 Panties looking all weird on G3F!!!
Whenever I put V4 Panties on G3F they look normal at first but when I bend the Legs a bit they start looking like this
Is there an easy way to fix this? This happens with every pantie I tried so far!!
1122 x 778 - 345K
  • Richard HaseltineRichard Haseltine Posts: 111,459
    edited September 2017
    AutoFit works by moving the clothes so that bits near a certain area of the original figure are in a similar relationship to the new figure, and by projecting the grouping and weights of the base figure into nearby geometry. Both processes can give unhelpful rsults in very confined areas where mutlple bones come together. Unfortunately fixing the issue is likely to at least need editing the weight maps, and may require soem adjustment to the mesh.
  • PadonePadone Posts: 4,334
    That is, autofit only does the gross job in most cases, then you have to fix it yourself. That's why an outfit specific for a given figure is always better than an autofitted one.
