Authenticity Poses and Expressions using thumbnails
https://www.daz3d.com/authenticity-mix-and-match-expressions-for-genevieve-7-and-genesis-3-female-s
I, I have this product. And it creates a little thumbnail image- instead of dials or WORDS to describe the expression.
Anyone else use these or have thoughts about this interrface or system of picking expression presets?
[as opposed to a SLIDER or regulr PRESET POSE pulled from a poses section in your Smart Library Tab area]
Am I supposed to do something with the Daz interface to make this more useful?
The image example of the facial expression is very small so I know - no vewndor means to have a product look like this.
I assume there was some setting somewhere to increase the avatar size. Never bothered with these, but Im on a bend to start getting use of out some of the products I've purchased in the past.
  • Dials are under your character in parameters on the right.
    1920 x 1080 - 485K
  • I think he means that there is no written description of the expressions and the thumbnails are too small to see details.
  • Kevin SandersonKevin Sanderson Posts: 1,643
    edited September 2017
    I just click and apply to see what they do to a character. YMMV.
    Post edited by Kevin Sanderson on
  • I meant on the far right side, it shows up under 'pose controls' as expression choices.
  • With these ones, you can "mix amd match" the upper and lower parts of the expressions to create your owm variations instead of being stuck with the defaults. I have a similar set.
