WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 1 unknown fo
rnollmanrnollman Posts: 310
Just downloaded the latest version of DAZ studio: DAZ4.5 and tried to change the color of the female hair content and got this message:
WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 1 unknown for QWidget)
What does this mean and how do I fix it.
  • Richard HaseltineRichard Haseltine Posts: 111,688
    Nothing you need to worry about and you don't. If you are having problems it's very unlikely to be related to that message, so more details of what you are trying to do and what is happening will be needed.
  • marcuswilmmarcuswilm Posts: 23
    edited May 2014
    Post edited by marcuswilm on
    Sounds like it's worth a bug report, then - open a ZenDesk Contact ticket for Technical Support.
    edited May 2014
    Ah, well that's a relief. I'm not sure what the recognition data option is - not something I see in the options with my Intuos 3, though I haven't updated for a while.
    edited May 2014
    Ah, thank you, Recognition Mode seems to be the default with the driver version I have.
    If you are getting errors or warnings in the log that aren't clearly the result of user error (even if you think they are the result of something you did that was an error, but ti wasn't clear that that was so) then it's worth making a report - it helps the development team to spot the rough spots if nothing else.
    edited May 2014
    edited May 2014
    At the moment you have to Send a support ticket in order to report a bug. Use Tech Support as the dept to send the ticket to. The Bug reporting system is in a state of flux at the moment and this is the only way to send a bug report.
    edited May 2014
