Need help identifying this Texture Shaded problem in Viewport
Dizpincels
I don't really know what to call it so I'm having hard time searching for answer. The black areas show up in the viewport when I select Texture Shaded view. Thanks in advance for your time and any help.
Rich
Windows 7 Professional
Processor Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
Memory (RAM) 32.0 GB
Graphics NVIDIA Quadro M4000
System type 64-bit operating system
Number of processor cores 6
Total size of hard disk(s) 5146 GB
Display adapter type NVIDIA Quadro M4000
Total available graphics memory 24288 MB
Dedicated graphics memory 8192 MB
Dedicated system memory 0 MB
Shared system memory 16096 MB
Display adapter driver version 22.21.13.8541
Primary monitor resolution 3840x2160
Secondary monitor resolution 1920x1080
DirectX version DirectX 10
Does it render OK? Those look like geometry or normal artefacts - oddly shaped polygons, doubled polygons or edges, geometry normals that conflict between neighbouring polygons. Is it a model you made yourself?
It renders great, I did not make the items, one of the items I have problems with is Time for School for Genesis 2 Female(s) and Time for School for Genesis 3 Female(s). Thank you.
Also the outfit in image I posted was Sassy Girl Shirt for Genesis 3 Female(s).
Also Also, everything works great on laptop. I have tried uninstalling and reinstalling daz3d on my desktop even going as far to remove registery entries.
Compare the settings in Edit>Preferences>Interface tab on both machines, though it may be down to the GPU/driver on the machine with the artefacts.
Settings are good, I even tried other graphics card ended up same results. I cleared the log file and when I load the shirt I get the following.
2017-09-24 19:31:18.363 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2017-09-24 19:31:20.727 *** Scene Cleared ***
2017-09-24 19:31:21.091 WARNING: fileinput\dzassetdaz.cpp(4639): Could not find node parent.
2017-09-24 19:31:21.438 WARNING: fileinput\dzassetdaz.cpp(1766): Failed to follow node.
2017-09-24 19:31:21.438 File loaded in 0 min 0.7 sec.
2017-09-24 19:31:21.440 Loaded file: tfs shirt.duf
2017-09-24 19:31:21.704 Loaded Morph Deltas in 0 min 0.0 sec.
2017-09-24 19:31:21.704 Loaded file: TFS Shirt Tucked.dsf
2017-09-24 19:31:22.068 Loaded image shirt white.jpg
2017-09-24 19:31:22.090 Loaded image reflection.jpg
2017-09-24 19:31:22.261 Loaded image shirt opacity.jpg
Thanks again,
Rich
Is it possible you have two copies of the shirt loaded without realizing it? I've seen something vaguely similar to that effect happen when you do that by accident.
Just double checked it is only one copy. One thing I did notice is that when you look at the inside of the Time for School shirt (or any other item I have this problem with) everything looks correct, it's just from view from outside that I see the problem. But with the Sassy Girl Shirt it'st both inside and out. :(
Thanks for your idea,
Rich
Is the opacity of the shirt set to less than 1 in the surfaces tab? This is an artifact I sometimes see in the preview window when there is opacity applied to a clothing item. Generally it renders correctly though
ETA. Try removing the opacity map from the surfaces tab and if the artifact goes away then you'll know if that's the issue.
You were talking about the Cutout Opacity correct? (it was set to 1). When I remove the map it turns the whole thing solid black. All I can think of is I must have corrupted some of file when I manual installed something. Happens now on both my desktop and laptop...lucky me :) Desktop is Quadro M4000 and Laptop is GeForce GTX980M.
Thank you for your help,
Rich
