Shower going dark
Mescalino
I have placed my character in teh shower and teh first thing i noticed was that her hair wasnt visible anymore.
When i render the scene this is what happened. (see screenshot).
The doors of the shower should be glass but they go dark...
I did notice that when i get behind the first window it looks ok. Its like the 2 windows cancel each other out.
EDIT even inside the room the shower windows are black.
1280 x 720 - 1M
Post edited by Mescalino on
3Delight? Probably too many refractive surfaces for the current maximum bounce number in Render Settings.
Yes sorry 3Delight. So i should increase the bounce number?
Yes, each surface with refraction will use one bounce so a lot of glass can quickly exhaust the default (at which point the render takes the colour of the current surface without proceeding further).
Where is that setting as i looked but did not see it under that name. I am now making a render using iray but i rather do it in 3delight in order to make everything look the same.
It´s the raytrace depht in the render settings tab. Set it to 2 or 3 and it should work!
I played with the settings and this is as best as i gotten it.
I tried to do it again but i moved the camera slightly now i cant get the same result anymore. However i only needed 1 image so for now this one will do.
I did try it in iray and it looked realy great but the differnece with 3delight is to big so i will have to remain on 3delight. Renders on iray take far to long since i have an AMD card and not a NVidia.
