About Dynamic Clothing Control
Faeryl WomynFaeryl Womyn Posts: 3,790
I just finished installing Daz and Hex and was wondering if I needed to install the Dynamic Clothing Control or do I only need my serial number for it?
  • SzarkSzark Posts: 10,634
    edited April 2013
    Yes and yes...it doesn't get installed with Daz Studio. But first make sure you have the updated version of the Dynamic Clothing Control. The end part of the version number should match the end part of the DS4.5 version number if that helps. :) I will presume you have the latest version but just check anyways. ;)
    Post edited by Szark on
  • Richard HaseltineRichard Haseltine Posts: 111,965
    You need to install it, DS itself includes only the basic plugin (they are different code, not just features that require a serial to unlock).
  • Faeryl WomynFaeryl Womyn Posts: 3,790
    I had reset them for fresh downloads and installs, and if I understood correctly the end numbers of the versions do match...both say 4.5 32 bit pc, hopefully that is what you meant?
    DS 4.5.1.56 will match the Dynamic Clothing Control with 1.2.1.56 but yeah fresh downloads so you should be good to go.
