Does Hybrid Grunge work in DS 4.9?
I'd just like to know if Hybrid Grunge will work in the latest DS software, thanks
    The only Hybrid Grunge shader I found was for Poser so the answer would be no.
  • BeeMKayBeeMKay Posts: 7,019
    edited September 2017
    Hybrid Grunge (if you are talking about https://www.daz3d.com/hybrid-grunge-bundle-for-daz-studio) is for 3Delight, so if you switch the render engine to 3Delight, it will work.
    However, you have to select the surface before you apply the Grunge, and the Rag-Erator does not work for some reason, though that might have to do with me using the beta and the scripts for the Grunge shader not being properly installed there).
    Here's a render done in the most recent 4.9 Beta:
    EDIt: The overlays do render nicely in Iray as well, so... here's a testrender of the same box, no change in surface settings, switched to Iray render:
    1263 x 947 - 154K
    1263 x 947 - 220K
    Post edited by BeeMKay on
  • FishtalesFishtales Posts: 6,238
    The only one I haven't used in 4.9/Iray is the Rust Icator as I don't have it :) They all seem to work including the Rag-Erater.
  • MelanieLMelanieL Posts: 7,885
    I used the Rag-Erator and Grime-Inizer in DS 4.9 Beta here: https://www.daz3d.com/forums/discussion/comment/2395751/#Comment_2395751 It's 3Delight though and from the date I did it I suspect 4.9.3 rather than 4.9.4.
    Post edited by MelanieL on
