Box as Meshlight how to emit to the inside only ?
Hi,
what parameter must I turn to let a box (a big cube) as an emitting meshlight to emit its light only to the inside?
iRay !
Hi,
iRay !
Emit one side only, then the light will emit on the "normals" side. However, since the normals are normally pointing outwards, you have to reverse the normals, and then it should work.
Hi Bee,
Invert the normals?
How to?
I used that primitive cube for the test.
Invert normals is an option with the Geometry Editor tool - select all of the polygons (right-click>Polygon Selection>Select All) then right-click>Geometry Editing>Flip Normals of Selected Polygon(s)
Thanks,
I somehow looked at the wrong corner.
