Joint Origin issue
I make a Sphere, import it, and the center/endpoints are on top and bottom.
So I open joint tool, adjust the center/end points to 0,0,0, memorize riggging, export, and import, and they are on top and bottom again
What step am I missing?
Don't go through OBJ, it won't preserve your adjustments (as you've found). Why not save as a prop asset in DS? Or there is a free script, I think still working, to export to PP2 and that should preserve centre/endpoint settings.
Thats true, I guess I can save as a Prop, since eventually that is what this will be. Thanks!
