Morphs between Daz 4 and Daz 4.5 ????
Faeryl Womyn
Someone had made some elf ear morphs for Genesis, without the need for the morph packages, however they were made for version 4 and do not work in 4.5. Does anyone know of a way to get these to work in 4.5???
There shouldn't be an issue using 4.0 files in 4.5 - how are they failing?
After installing the morphs, I opened daz and tried to find them to apply but they were nowhere to be found, they don't show up and I tried placing them in a different area, in case that was the problem and still they wouldn't show up. I tried asking the creator but other then to say they would look for them and update, there has been no more answers from her.
The morphs in question are linked below.
http://www.sharecg.com/v/57817/
I have this morph - it should show up in the Parameters tab, not the Shaping tab like most morphs do. Select the head of Genesis, go to the Parameters tab, and you should find the morph there. Hope this helps you out.
Ok will try that and hope for the best.
It worked and thank you all for your help
