Does V4 have full functionality in DS 4.9???
I have Victoria 4 and her various Morph packages
Morphs++
V4 Elite Ethnic Faces
Base V4
Do these packages work in DS 4.9?
IF so, HOW do they work?
I have used these successfully in DS1 - DS3A with NO problem!
Is there a special trick or do they just not work?
I have them loaded, I double click, but they don't appear in the Parameters tab OR the Shaping tab.
Vicky 4 was selected at the time, still no morphs
Any Help will be appreciated!
I'm running DS 4.9 (64 Bit) on Windows 7 , 4Gig RAM
  • nemesis10nemesis10 Posts: 4,038
    Morphs++
    Base V4
    How did you install them.  IThey can not be installed via Connect.  If you install through DIM or Manually, you do have to the old initialization thingie:
    You  initialize the V4 figure by browsing to the 'folder you installed your stuff'/runtime/libraries/!DAZ and Click on both: (in Windows; there are Mac scripts in the same directory)
    • DzCreateExPFiles-V4.bat
    • DzCreateExPFiles-V4V3.bat
    EDIT: Also do this with the .bat/.command files for M4 and his bits, too
  • tsaristtsarist Posts: 1,642
    THANKS Nemesis!
    You saved the Day!!
    Morphs are found and being used!!!
    THANKS!!!!!!!!!
  • If you also install the PowerLoader files you can select which ExP morph expansions are loaded when you load the figure, and have the option of loading or not loading the slots for others to inject into.
