string on a new line (I/O file)
YudinEdYudinEd Posts: 90
var sPath = FileDialog.doFileDialog(false);file = new DzFile( sPath );file.open( file.WriteOnly );var str1="1th string";var str2="\n 2th string";file.writeLine(str1+str2);file.close();
Hi! Why  does not work \n ? How can I write a string on a new line?
Post edited by YudinEd on
  • Works for me. Are you perhaps using a text editor that requires a carriage return and a line feed for a new line to view the output?
  • YudinEdYudinEd Posts: 90
    edited September 2017
    Thanks for answer.   I did use the Notepad and the Wordpad (default text editors in Windows 7) - it don't work :(
  • It worked in TextPad - Notepad is quite limited.
  • SimonJMSimonJM Posts: 6,097
    Using Win7 Pro I it works, partially.
    Viewing in Notepad I see:
    1th string  2th string
    (when I C/P that in here I get the linefeed)
    Viewing in Wordpad I see:
    1th string
     2th string
    Smacks very much of what Richard says - Windows 'wants' crlf (\r\n) as a 'proper' end of line, and if I add a \r immediately before the \n and re-run then Notepad does show the linefeed.
    Post edited by SimonJM on
    Thanks. \r\n is fine working. In Notepad too :)
    var sPath = FileDialog.doFileDialog(false);file = new DzFile( sPath );file.open( file.WriteOnly );var str1="1th string\r\n";var str2=" 2th string";file.writeLine(str1+str2);file.close();
