Unzipping files manually to XP Problem resolved !
AJ2112AJ2112 Posts: 1,417
After hrs of brainstorming. I just delete all content, start over again, finally figured it out. Hopefully this thread can help others, running into the same issue.
Each time I copy paste folder, I get a dialog box:
This folder already contains folder named Pusey Design. If the files in the existing folder have the same name, blah, blah, blah. Do you still want to move/copy the folder. I would click no in fear folder would be replaced with new, so I rename the folder, insert in to desired location. Content work'd, but incorrectly.
This time, when dialog popped up, I clicked yes, to move/copy folder. Bingo !! Content working perfectly !! Texture/Materials, all of it. Wow !! after hrs upon hrs, I finally figured it out. Something so simple and yet complicated. Alright now, I can apply new fashions to Genesis model, opposed to Ninja outfits, Lol !!!
  • WilmapWilmap Posts: 2,917
    Folders should be merged so that all content is in the same folder, otherwise you confuse DS.:-)
    Glad you got it sorted.
    Its Windows, not an old Mac, you don't need to fear merge, click 'Yes'.
