New to Reality Plug-In
Hello! I'm new to Reality Plug-In and I have a question. I'll try to be clear as possible. In my viewport in Daz, I have Genesis in portrait view, per exemple.But when I render the frame in Reality, she appears in the default position, and not the view set in the viewport.
Any help ould be very appreciated, thanks!
Also, I do not seem to have luxrender.exe installed, is this the issue?
Post edited by Genevieve Laroche on
  • SimonJMSimonJM Posts: 6,101
    edited September 2017
    If you have (one of) the latest versions of Reality instaleld then it will also install a version of Luxrender.  Not sure if it's the latest but I have 4.3.1.16203 installed and that came with Luxrender (and put it in c:/Program Files/Reality_DS/lux and does not give you the option of changing that location).  To check this select the Render tab, then the Render button and that will show you where Luxrender should be.
    For the viewpoint thing, click onthe Cameras tab and make sure that you are using the same camera as your viewport - it won't, for example, use the Perspective 'pseudo camera'
    Post edited by SimonJM on
  • Thanks so much! It works.
    Glad you got it working
