render progress window gone after updating to 4.9.4.122 [SOLVED]
PadonePadone Posts: 4,314
Everything works fine. Also I got no errors in the log. But the render progress window doesn't show up. When I render with iray it only shows the rendering window and not the render progress. Is there any way to get it back ?
Post edited by Padone on
  • Are you sure the progress bar isn't hidden behind the render?
  • PadonePadone Posts: 4,314
    edited September 2017
    Yes it is ! It was just hidden behind the render window. Thank you Richard I guess I'd never thought about that without your help.
    EDIT p.s. Anyway placing as default the progress bar before the render window rather than behind would probably make more sense.
