serching free tool, which can make AVI or mpeg from png sequences
kitakoredaz
Now I have rendered png sequence image,, 0 to 951
then,,,,,, Is there any good "Free" tool ? @@;
I check Live movie maker ,, but it seems make slide show from PNG sequences,, not movie.
or some tool may need to use comand line etc,,
I hope simply drug and drop,, and it can set simple effect or trim seems more better,,
I am using pc 64 bit ver now,,,
(I have no plan to buy movie tools untill I understand more about 3d tools,,
so simply serch free tools,, it can make animation (not slide show) from png sequences,,
Get this VirtualDub it comes in 64bit and I use it myself.
Yeah,, I got it,, Thank you! much ^^
first I checked the page,, I could not clear understand,,,how manage png sequences,,
but is can read easy from file menu,, and just save it as avi now @@; (change frame rate,,)
it seems my big first step. (Actually before I just rendered as AVI, in daz studio,,%-P)
now,, I make image files from png sequances,,,
then hope to next stage ^^; modify image files,,,
if I hope to cut off some sequences,, or modify mistake frames (Camera did not follow well,, and some move seems slip away,)
in ds and render again as png,,
after that,,which tool (hope,, free,,,) you recommend ^^;? about these caes,,
first,, I need to make AVI movies segments
eg part1.avi (000 to 029)
part2.avi (042 to 125)
then join part 1 and part 2 ?:roll:
To fix parts do this in VeeDub. Only load the Good parts (You can pick a range or just move the rest to another folder) and Save as AVI. Now render the bad Parts again. Load those renders and Save as AVI. When you have the two Avi's load your first one then use Append Avi Segment to add the Second Fixed part. I use that to make a LONG animation from Small scenes.
I render each Scene as .PNG files then convert to AVI and then just Append each part as I do them.
I Hope this helps.
Ya!! it actually help me lot
and sorry,, I am too tired to read many documents these days,,,,then missed them ^^;
