Complex clothing autofit
I find G2 -> G3 autofit usually works, but it's really having bad time when it comes to clothings with unusual shapes.
for example, this kimono for G2F is lot different from other cloths.
https://www.daz3d.com/peony-kimono-for-genesis-2-female-s
I tried all options (AutoFit, Transfer Utility, having it worn on hidden G2F, etc) and all failed.
Is only remaining option is to go and change all bones / weight maps by trial and error?
Hope there's better way... but maybe that's much there is to it
Hello
try dynamic solution. I don't have access to an image I made with the kimono you mention on G3 so here is another one : a V4 kimono (4 layers of clothe) on a seated G3.
But it's not a one click solution!
Dynamic solution, hmm. What did you use? VWD?
Yup!
I second the suggestion of using VWD. I've got a template set upcoming that will re-add bones to a lot of items, but I couldn't figure out a way to include a "super long sleeves" solution that would work with enough different items.
