High Sierra macOS and Carrara?
Hi there
High Sierra on Mac is not far away.
Has anyone run Carrara under the HS Beta?
Mic
  • Just installed on a test machine (I kept an old Macbook Pro for this very scenario) and Carrara launches and seems to play OK with High Sierra.  Only played around for a couple of minutes, though, so I am not certain yet.  I also am not a heavy user of Carrara so I cannot test everything.
    The day will come where Carrara won't work with a new OS and then I plan on getting a new computer, leaving the old one for Carrara.  Mac minis aren't too expensive  for this, nor do they take up much space.
    I've just upgraded to High Sierra (MacOS 10.13), and both Carrara and DS (and Modo wink) are working fine.
  • Has anyone tested it on a APFS volume? The new file format is what has broken some older software.
