Environment on Yoga Studio
So I know how to get a backdrop which I usually don't use. I normally turn the Draw Dome on and allow that hdri to be the backgroud and a light source and it always seems to work just fine. But on the Yoga Studio I have tried to get a background as a pic instead and its only showing the hdri regardless of whether the Draw Dome is on or off which is weird. Only happens on this Yoga set. Any ideas?
1340 x 1802 - 3M
  • ElliandraElliandra Posts: 642
    edited September 2017
    Hi Vanishot!
    Have you tried plugging the background image into the Environment Pane yet? If you have the Background image set to None in the environment pane the HDRI will render, if you have a background image plugged in then that will render in the background of your render window.
    Elli
    Post edited by Elliandra on
  • DDCreateDDCreate Posts: 1,424
    I have this environment too and I used the Environment Pane for my backdrop like Elliandra mentioned. Little addendum....you may have to tinker with the opacity dial a little for the windows. I think that's what I had to do.
